My large slideout wiper, on top of slide, used to roll under by itself, when retracting the slide. Now, after being a couple years old, it will not roll under, unless I start it manually. My owners...
Generally, if a unit sits outside open to the elements, the seals will loose elasticity. As I recall, Winnebago recommended using corn starch. Probably doesn't really protect the seals, but it does cut down on friction and gives a smooth wipe. I still use it on mine along with the seal protectant. Good luck.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
