64thunderbolt
Jan 30, 2015Explorer II
Solar Kit
Just received my kit. 2 100w panels with a 30a pwm controller. Hoping it will recharge my 2 GC2's. I am alone in the trailer and power use is min. Any thoughts?
DAS26miles wrote:
Going to do a test at Death Valley soon and will see if I really need an additional 50 or 60 watts. May get by with only needing 30 watts and Renogy has a 30watt panel with 15ft cable and alligator clips at the ends for only $65. That may be the cheap way out. No need to get a 20 or 30 amp controller and the existing wiring is adequate. Yes, I can buy all kinds of things to make it more efficient. We will see???
I am surprised that the Renogy 30 watt panel doesn't need a controller and hooks directly to the batteries.
DAS26miles wrote:
Can the suitcase panel's 15awg cable bypass the existing controller and be attached to the added panel. From the added panel run 10awg to a new Solar30 controller at the MH Then 2feet of 10awg fused at 10amps to the batteries? I would add Anderson SB50 connectors for ease in setup and takedown. I believe this should cut the voltage drop, right?
wbwood wrote:Hav'nt had it out in the field yet (around the house chores). But it seems to get the batteries up to 100% in the 3 hrs of sun that can get to it with a minimal load on it. I just have 2 Costco GC 2, what ever the amp hrs are on them.jandjbaums wrote:
I went with 2 Renogy 100w poly panels for my portable setup. also have the MS 45 controller, and the 2030 monitor for future expantion.
How is working out? What kind of battery bank?
