Bill_Satellite
Jan 08, 2020Explorer II
While I suspect that the information above is correct about which is positive, the best advice is to check the connections with a multimeter. Set the panel in the sun and put your probes on the 2 connections. If you have red to red and black to black you will see a 12V (or whatever) reading. If you have it backward you will see -12V.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
