BFL13's avatar
BFL13
Explorer II
Oct 08, 2013
Solar Panel Voc-MPPT?
Wondering if there is any relationship between measured Voc and MPPT performance with a 24v panel.
My 12v panel has a Voc rating of 21.9 and Isc of 8.2, but I often see 8.2ish when Voc is only 20.3ish. That's fine, I just want that Isc. ( I know they have different coefficients from 25C)
But now with MPPT and a 24v panel I am seeing the same sort of thing.
Panel is rated Voc 37v and Isc 8.3a In the sun trying it out I got 34.5 Voc (varies -did see 36 at one point) and Isc of 8.24a
Normally, I would be happy at seeing that Isc, but now I am wondering if that 34.5 Voc instead of 37 rated would show up as lower amps to the battery via the MPPT.
(Vmp is 30v and Imp is 7.7a)
Is it still the case with MPPT that if you are seeing the Isc at the panel, all is well, or with MPPT does Voc matter now, or what?
Thanks.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
