Airstreamer67
Jul 22, 2017Explorer
I thought my TPO was waterproof and not susceptible to water seepage as long as it's not been cut etc. So, why the need for a general roof coating on it?
I know the Dicor sealant is compatible and effective on the roof seams which must be protected against water seepage. A periodic inspection can show if the Dicor on the seams is cracking, at which point a new coating can be applied to seal the cracks.
My 2006 trailer with TPO is still waterproof. I check it periodically visually on the outside and with a moisture meter on the inside. I've used no roof coating except the Dicor on the seams when needed.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
