- rexmitchellExplorerBeen using Seafoam for years. Great stabilizer but also cleaner.
- wopachopExplorerStar Tron for anything gasoline.
Archoil for diesel.
https://www.amazon.com/Star-Tron-Enzyme-Fuel-Treatment/dp/B001VMNHX8
https://www.amazon.com/Archoil-AR6200-16-9-ounces-Treatment/dp/B005WWP99S - Harvey51ExplorerSo Seafoam for gasoline and Diesel engines is the product best for keeping my grass trimmer carburetor clean. Thank you!
- AirdaileExplorerYou can also take a gas can down to you local general aviation airport and get some 100LL avgas. This stuff has a 2 year shelf life.
I see you're in SoCal so there aren't many left. - BobboExplorer III
pianotuna wrote:
suprz wrote:
I have never seen it in gallon cans.. I wish I could get one of those
Try Autozone.
That is where I get mine. - pianotunaNomad III
Try Autozone. - suprzExplorer
Harvey51 wrote:
Sea Foam appears to be a corporation with many products. Which one should I use to prevent carburetor problems with the snowthrower and riding lawnmower? I always use gas free of ethanol grass Trimmers. I had a Stihl and it needed a new carburetor every spring until I gave it away. Now I’m hoping a Home Depot brand will be better.
Amazon.ca search finds 100,000 Sea Foam products. Locally, in automobile repair shops I see maybe a dozen. Which one to buy?
If using ethanol free gas, I would just run the engine out of fuel and put it away for winter. But if you want to use seafoam, I just eyeball about a shot glass of seafoam per gallon of gas. - suprzExplorer
Bobbo wrote:
https://www.amazon.com/Sea-Foam-Extreme-SF-16-Seafoam/dp/B0002JN2EU/ref=sr_1_1?keywords=seafoam&qid=1575689535&sr=8-1
Available at any big box auto parts store. I buy it in gallon cans and refill a couple of the 16 oz cans.
I have never seen it in gallon cans.. I wish I could get one of those - BobboExplorer IIIhttps://www.amazon.com/Sea-Foam-Extreme-SF-16-Seafoam/dp/B0002JN2EU/ref=sr_1_1?keywords=seafoam&qid=1575689535&sr=8-1
- Harvey51ExplorerSea Foam appears to be a corporation with many products. Which one should I use to prevent carburetor problems with the snowthrower and riding lawnmower? I always use gas free of ethanol grass Trimmers. I had a Stihl and it needed a new carburetor every spring until I gave it away. Now I’m hoping a Home Depot brand will be better.
Having RV issues? Connect with others who have been in your shoes.24,329 PostsLatest Activity: Oct 28, 2025
