j-d
Jan 13, 2018Explorer II
Are these Kwikee Steps? If so, look under the part of the step that actually bolts to the bottom of the entry area. Find the Control Unit, a black plastic box. Box itself is square, but the newer versions of the step use a Box with an extended mounting tab on it. Looks like a triangular "fin." The earlier one mounts with its crews closer to the Box, no "fin." Newer "with fin" service guide is Manual #888 Fin shows in Figure 3.
The "no fin" service guide is
Manual #875 No Fin shows in Figures 1. and 2.
This Notice discusses the difference between the steps covered by #875 and those covered by #888
Finally, here's Kwikee's Troubleshooting Flow Chart
Ours is powered through a circuit breaker off the coach battery. When ours malfunctioned, first time it was a bad ground connection. Another failure was one of the gears in the motor assembly. I was able to repair it with a Ford Power Window Gear Fix Kit.
