j-d
Mar 27, 2018Explorer II
You're welcome, but Did You Fix It? Hopefully Yes and if so What Did You Do?
We had two failures on our Kwikee Steps using Manual 875. The first failure, was the Step deploying and retracting at random on the road. Turned out to be a poorly crimped wiring connector. No parts but a couple new butt connectors. Second was the "slip clutch" in the motor gearbox broke up. Fixed it with a HELP line kit from the auto supply. Hopefully yours went easily and well!
