CA_Traveler
Mar 30, 2021Explorer III
The main CONVERTER BREAKER (I believe it is also 40 amps) had popped. I believe this breaker is the master control for the 12v wire going into the converter that goes to all 12v systems.Find out what it does so that you know. Is the RV wired so that the breaker is carrying the sum of converter and solar for example?
Is the wiring adequate because if not then that could be a concern.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 07, 2026
