CA_Traveler
Mar 31, 2021Explorer III
BFL13 Reasonable analysis for warmer temps but designs should include lower temps which raise panel power. Interesting that you didn't again bring up lens or cloud effect. I agree that it's likey a panel CB fault which can be eliminated as it serves no purpose.
For general estimating purposes I use 66% of panel power for 4+ hours. On a clear hot Phoenix sky in June I pushed my loads and got 53A from the controller with 750W panels. But I designed for for cold temps as well.
And it seems likely the OPs 2 problems are unrelated but w/o details who knows?
OP Recommend you replace both CBs with better quality ones if not eliminate the panel CB. Then see if you repro the issues.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
