pianotuna
Mar 31, 2021Nomad III
SJ-Chris wrote:
The one in the photo (Converter Main Breaker) has never popped in the ~1.5 years that I've owned the RV. Until yesterday. After feedback here and thinking about it more, I don't see how the solar/inverter install could have caused this since those components are basically hooked up directly to the batteries and not through this breaker.
Thanks!
Chris
I can say, that in the old days when I used "double conversion" (plug in only the converter to shore power, and use an inverter to run the rest of the RV loads), that I did cause the reverse polarity fuses to deform.
You might want to have a look and see if your fuses are pristine or not.
The converter in mind is a 30 amp unit--with 30 amp fuses.
