rwagner43's avatar
rwagner43
Strange problem with Dometic RM2812 fridge
Our kid’s family took our old RV on a trip and told me that the refrigerator worked fine as they were driving, but when they hooked up to 120 VAC eventually only the freezer section seemed to work. The refrigerator section didn't feel cold at all. When they returned I started testing.
The refrigerator is a 14 year old Dometic RM 2812, which itself was a replacement for the original fridge. Using propane and starting from 85 F outside ambient after 3 hours the freezer section was below freezing and the fridge was at 44 F and still dropping slowly. Since this seemed normal I stopped the test and went home.
The next day using 120 VAC the freezer section got below freezing, but the fridge section would not go below 68 F.
According to the Dometic Service Tips manual the electric heater element for the RM 2812 is rated at 325 W +/- 10%. A clamp-on ammeter shows it is drawing 2.5 A which is about 300 W which is within spec. By feel you can tell the electric heater is getting hot.
I ordered a replacement circuit board (Dinosaur Micro P-711 on sale at PPL Motorhomes) and replaced the board. The new board did not cure the problem, but at least we now have the added feature of adjustable temperature.
If there was some sort of blockage in the pipes between the freezer and the fridge it seems like that would also affect propane operation.
Of course we can use the fridge on propane only, but we would like for it to work on electricity too.
Any suggestions? Thanks, Rick
  • Gjac's avatar
    Gjac
    Explorer III
    If it has been in for a while it may be rusted and hard to remove. When I replaced mine I had to used long needle nose pliers and twist if back and forth about 1/ 8 in at a time. I also had to make some tooling to pry up on the bottom of the element while twisting. Mine was in there for 14 years when I changed it so maybe yours will come out better. Before I installed the new one I cleaned out the hole with emery paper and steel wool. Good luck.
  • rwagner43 wrote:
    Doug, The RV is 30 miles away so I can't look at it now. Do you think it will be necessary to pull the fridge completely out in order to gain access to the heating element, or can it be done in place from the rear? I recall that it seemed difficult to split apart the big pipe that holds the element with the fridge installed. Thanks, Rick
    In 10 years of working on RV's and doing quite a few fridges, I've never had to pull the fridge out to get the 110v heating unit out.
    Be sure to blow the holder with some compressed air, or vacuum. But the point is to get as much foreign material out so the heat transfer is good.
  • Doug, The RV is 30 miles away so I can't look at it now. Do you think it will be necessary to pull the fridge completely out in order to gain access to the heating element, or can it be done in place from the rear? I recall that it seemed difficult to split apart the big pipe that holds the element with the fridge installed. Thanks, Rick
  • Old-Biscuit wrote:
    Disconnect electric heating element leads at control board.....measure resistance across the two leads.......should be 44 ohms.
    If not .......replace heating element and clean out element holder of any rust/debris so element is making good contact and transferring heat properly
    Since his amp reading is spot on the heating element is good. I would remove the heat element and install it in the next heat element slot as the original slot holder may have slightly detached from the flue. IF you cannot remove the existing Heat Element (odds are it is frozen in place from 14 years), then purchase a new element and install the new one in the extra hole. If it works on LP and NOT on 120 and the element pulls the 2.5/6 amps the only thing left is to move it to the other hole mount. Doug
  • Disconnect electric heating element leads at control board.....measure resistance across the two leads.......should be 44 ohms.
