jodeb720ExplorerDec 24, 2018Suburban Anode Replacement - Anti Seize?I'm replacing my Anode, and I had to work pretty hard to remove the anode (alternating between tightening and loosening as well as penetrating oil). I know if I wrap the threads in teflon tape, the...Show More
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 22, 2026
Related ContentSeized Onan...rebuild or replace?Removing seized shackle bolts?Replacement of Suburban water heater...Suburban SW12DEL Water Heater On/OFF switch melts???Suburban water heater replacement issue
