robsjo's avatar
robsjo
suburban hot water heater
water heater wont fire on gas,tested the 2 coiles and 1 is no good,need to find anew coil,where to look thanks ROB
  • If it a Suburban SW6DE go to the PPL Motorhome parts store and search for 3475. It will bring up a White Rodgers coil that will work. Under $30 and you are done.
  • Depends on which gas control you have.
    Here is some info about the two different gas controls Suburban used.....LINK
    ID the ones you have then do a goggle search with that part number for availability..replace both coils.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
