bshpilot's avatar
bshpilot
Suggest: ac/dc Inverter withOUT charger
Does anyone know of an dc to ac inverter that has a transfer switch and does NOT contain a charger ?
My tiny (xantrex RS400) inverter stopped functioning and its no longer available so I'm looking for a replacement with similar functionality.
I need less than 1500w, mostly to run a Flat Panel TV, I dont need another charger (or converter/inverter/charger combo unit) all i really need is an inverter, with a built in transfer switch.
Pure sine wave isn't necessarily required since the TV already has its own power supply in it & no other device that i would run is either sensitive enough nor w/out its own power supply such that pure sine wave is necessary (feel free to correct me if I'm wrong here).
The inverter needs to have AC pass-thru / transfer switch capability so that when I'm on shore power the inverter isn't being used (or consuming battery power)....rather it should just pass the AC voltage/current thru the unit to the appliance.
The Xantrex freedom HF's would be fine (if it didnt have a charger or i could disable the charger).
Id even settle for the Xantrex ProSine (2.0) but again its got a built in charger that i don't need.
Are there any inverters available (with built in transfer switches) that permit disabling the charger or don't have a charger built in ??
Having RV issues? Connect with others who have been in your shoes.24,291 PostsLatest Activity: Jul 28, 2025
