Travelin2's avatar
Travelin2
Suggestions needed/changing dump valve seals
The dump valves were getting a little sticky and hard to operate at times so I figured I would just pull them off, inspect the seals, lube them up with vaseline and bolt them back up. Easier said than done. On previous rigs we have had it was a snap but on this little 2012 Freedom Elite 21C the connector between the two tanks is a one piece and there is no way to get clearance to reinstall without displacing the seals as you force the "Y" back in place. I loosened the clamp on the tank outlets to let the adapters move farther into the tank but they were both already bottomed out. I then blocked up under the grey tank and removed the retaining clips in hopes that the plumbing attachment might flex enough to give me a little play. No dice. I finally just used brute force and flexed the sidewalls of the tanks in enough to get the unit, with seals in place, started and then wiggled and pushed until it was home. It looked OK, the bolts all went back fine and when testing for leaks I found that they both held water just fine with a full tank but when draining with the valves open the gray water valve leaks. Back to the drawing board.
I was hoping someone can shed some light on the correct way to get some clearance while doing this. The only thing I can figure is that the tank adapters that slide into the tank are not supposed to be all the way in when things are glue together so a person can loosen the clamp and slide it on deeper into the tank outlet for relief. The boys at Thor must have lacked a little when building this. I welcome anyone insight into this problem......can't seem to get picture to show.
http://i132.photobucket.com/albums/q29/jwcox2006/DSCN1136.jpg
  • John Wayne wrote:
    some one posted on this before and he used thin metal shims on each side of the valve as he slid it into place to hold everything together till it was lined up and then pulled the metal out.
    That sounds like a plausible solution. While on this topic I wonder what the reccomended sealant for the tank inlet is. It has a clamp on it so I was thinking of using butyl tape. Any other ideas?
  • I replaced my cable style black water dump valve by using one of the bolts pressed against one side of the valve while the other end went through the bolt opening on the other half. I used a nut to force the two halves apart and hold them apart while I wiggled the new valve with new seals into place. I had to put the valve in an angle to clear the bolt. I then loosened the nut until the two halves closed in on the seals, removed the bolt and nut then rotated the valve into place. This was not an easy fix. Hopefully, someone has an easier way.
  • some one posted on this before and he used thin metal shims on each side of the valve as he slid it into place to hold everything together till it was lined up and then pulled the metal out.
  • I can remember doing this, and discovered that by leaving the valves open when installing, it allows more clearance for getting them back in place. But, I will NEVER replace just the seals again ! I replaced them BC they were leaking, but I ended up w/ very hard moving valves, and no visible reason for it. I should have replace the complete valves,....not that expensive.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
