wopachop's avatar
wopachop
Switching from Genny to Shore Power under load----bad?
Got to the trailer and started the genny its been over a month.
Then plugged into shore power with an amp reader because i was curious if it would switch over.
Started the A/C and let it run for awhile.
Then turned off the genny with both A/Cs cranked full blast.
Only hooked up to 15amp.
Ran and killed the front bedroom manual hand dial.
Then turned the main room thermostat to off.
What damage can that cause to the electrical switch and the air conditioner?
