DrewE
Jul 19, 2018Explorer III
Any of them should work just fine. The resistances of the tank contents and the resistor pack are in the range of kilo-Ohms; all you need is more or less continuity. Solder and heat shrink is just fine; a weatherproof telephone connector would also be just fine if it's suitable for the type of wire (I think some are designed for solid wire only and not recommended for stranded wire).
It would seem to me to be a good idea to tape or otherwise restrain the wire and its compatriots so it doesn't run afoul of the leveling jack again.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
