NinerBikes's avatar
NinerBikes
The 12V power source solar panel
So I came across this on EBay... and they are very local to me... but it sounds like a $100 experiment gone bad.
The specs on this thing are waaaaaaay different than any other 12V solar panel that I've ever seen.
Max V 15.03V?
Amps at short circuit 7.92?
Vmp... 11.97
Could someone with more brain power than me check the specs on this and tell me it would charge a Trojan T-1275 without even the need for a charge controller?
What about diodes and sucking juice out of the battery and back into the panel?
Thoughts?
Funky Spec'd 100 watt panel with huge amps.
Do you run this with one of Mex's Voltage buck / boosters, then through a charge controller, so that there is enough V to charge a battery properly at bulk mode, 14.8V and give up a few amps in the process?
Need help, guys, but in layman's terms, EE's and above need to dumb it down to terms a Finance major can handle.
Having RV issues? Connect with others who have been in your shoes.24,368 PostsLatest Activity: Mar 11, 2026
