jloftin60's avatar
jloftin60
The 13.5 A/C will not cool rear bedroom on DP. What to do?
I live in South Louisiana where the summer time is very long, hot and humid.
My problem is after traveling, the rear A/C can not cool the rear bedroom. The heat from the diesel engine adds to the problem along with the 100* degree outside temperature.
I like a cold bedroom at bedtime. I have tried a fan, but no help.
Would it be worth installing a larger rear A/C 13.5 to a 1500 BTU?
The front A/C seems to cool ok.
What other ideas would work?
  • Look at adding some good double foil quilted insulation under the bed over the engine and around the sides of the bed box.
    I did that and it made a fantastic difference.
  • I do run the generator and both A/C'S while traveling.
    2002 Fleetwood Discovery with the air ducts in the roof.
    One small vent in the bedroom roof. I wish it had more air
    volume blowing through it.
    Maybe the 14 year old A/C's need updated.
  • Need a lot more info. Year/Brand/Model of motorhome. Ducted or NON ducted. Your problem is the opposite of what most RVer's have. Due to the Bedroom having to turn over less volume of hot air, the bedroom AC usually makes it quite cold in the bedroom. Are you positive that the rear AC is cooling at all? going from 13.5 to 15 will not create a greater cooling factor. Will help a little but if NOT hardly cooling with a 13.5, then the extra 1500 will not help that much more for the cost.
  • Park in the shade.
    Run both roof AC's using the generator while driving.
    At night run the bedroom AC to a very low setting. Then during the day it'll have a chance to keep up.
Having RV issues? Connect with others who have been in your shoes.24,316 PostsLatest Activity: Sep 13, 2025
