scrubjaysnest
May 06, 2015Explorer
Almot wrote:
3A furnace is nice, but 18.64 WH is if you run it only 30 minutes a day.
Otherwise - no surprises. My daily draw is about 35 AH or 440 WH a day, without furnace but with laptop.
It looks like you need a bigger battery bank.
That is worst case and 47% soc is slightly below the desired goal of 50%. With the TM's real estate is a major problem for batteries and solar.
Our normal usage drops the batteries 15% per day and with good sun the addition of the 120 watt panel has raised our roc to 7% so no for us a larger battery bank isn't needed.
As for the heater the name plate data says 16 amps but have never measured it anywhere near that.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
