fyrflie
Mar 28, 2023Explorer III
I just did my Dometic cooling unit. Purchased from RV Cooling Warehouse but came with JC Refrigeration stickers on it.
As others have said, you need help getting it out of and back into the hole, but otherwise a fairly easy process.
I do not have any slides, so my space was tight, but got the refer to the bedroom where I could lay it on its face and complete the work.
Another thing to check when you have the refer out. Insulation of the walls and any baffles to correct the airflow up and around the cooling unit when installed.
One thing that RV Cooling Warehouse suggests is that the Camco refrigerator vent cover does not allow for proper air flow for a Dometic refer. I purchased a Dometic roof vent and cover and you can definitely see the difference in design.
Also consider adding exterior and interior fans.
Good luck with your project.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
