RVhiker's avatar
RVhiker
Thetford Style II
We have a Thetford Style II toilet; this has a lever on the right side of the toilet that you step on to flush. Sometimes, that arm is slow to return back upward; when this happens, the water valve and the flush valve are slow to close. Once the arm returns upward, the water valve and the flush valve close properly. There is no leak from either the water valve or the flush valve.
I have sprayed the flush valve with silicon spray several times. This only temporarily solves the problem.
Can anyone tell me if the problem is likely a problem with the flush valve seal, or some problem with the water valve, or something else?
