GlennLever's avatar
GlennLever
Thingamabob disconnected on top of Cummins engine
In the process of the regeneration of my 1997 American Dream it was found that this doodad on top of the engine was disconnected.
I suspect that when my meniscus ConWay was working on the engine it was disconnected / stepped on, while the work was being done on the exhaust manifold.
It looks to be a pressure sensor more than a shut of solenoid but could be either.
There was one wire laying there broken so a new end was put on it and connected to the doohickey.
It could be grounded through the unit but the second terminal certainly looks as if it had been protected from the elements making me believe that there was another wire connected to this gizmo.
Does anyone know what this is, what wires would be connected to it (pictures would be outstanding).
Other interesting stuff on this coach can be found here
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27344098.cfm
  • Latest response from Cummins
    Glenn,
    I believe my co worker said he would be ground wire and then they can add leads to the solenoid. If you want, I can see about my co worker explaining that to you if you need better understanding. He is more technical than I am, so I may not be relaying that information as well as he could.
    Mark
    Customer Care Representative
    If we have misunderstood the information in your communication or you have additional questions please feel free to respond to our support staff by e-mailing powermaster@cummins.com or call Monday through Friday, 7 a.m. to 7 p.m. ET at 1-800-DIESELS (1-800-343-7357). If you are located outside of North America, you can reach us at 812-377-3000.
    For authorized service center locations please visit:
    http://www.cummins.com/cmi/index.jsp?siteId=1&langId=1033&newsInfo=true
    Cummins.com
    Everytime.cummins.com
    Almost sounds like I am talking to India??????
  • I received a call from from Cummins today.
    It is a solenoid/valve. The wire is a 12volt supply that should only be hot when the wait to crank light is on on the dash. It is part of the intake heat system. There is not ground wire, it is grounded through the valve body.
    The one tab that appears to be clean and should have had a wire connected to it should be folded over, and be flat against the valve body. When this has been done I suspect we will find that the other side, the side current not showing, will show the signs of passing time.
    So... all questions have been answered at this point. Thanks for all your help.
    I did receive a finial e-mail.
    Hi Glenn,
    I heard you spoke with Mike. Was he able to answer all your questions about the part?
    Mark
    Cummins.com
  • Solenoid Picture.
    This is the solenoid in my C8.3 325HP engine. No connection used for second terminal, in fact there is paint, partially peeling, on the terminal which leads me to think that yours also had paint on it and has only recently lost the same. As you can see where the paint is flaked the terminal is more shiny.
  • jtfcons wrote:
    Solenoid Picture.
    Thanks for your reply, that certainly would explain the shinny terminal. We suspected that it had been step on by a Conway pretend mechanic.
  • You mean right there where it says "WARNING---DO NOT STEP"
    Yep, but my decal is missing so that must be the reason they thought it was OK.
    To be clear this was Conway Volvo truck & Bus that did the damage, and not Caledonia RV. Caledonia RV has been outstanding where Conway Volvo truck & Bus was a night mare and I got the state to step in and make them refund a bunch of money (that is how bad it was.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
