kzspree320
Oct 28, 2017Explorer
I decided on the TireMinder and bought the A1A model. Its psi readings are usually within 2 psi of the manual tire gauge readings the few times I tried it (keep tires at 105 psi). One of the main reasons I went with TireMinder is our friends have used one (older model TireMinder) for about 3-4 years on their 38 foot diesel pusher and the Jeep Wrangler toad. He highly recommended it and my limited experience thus far has been excellent. It's very easy to install. Alarms for fast leaks, slower leaks, low pressure (15% or more less than base pressure you set), high pressure (over 20% more than base pressure you set) and high temperature over 167 degrees.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
