roaminaround's avatar
roaminaround
Toilet blade seal leak
I'm starting a new thread because this is model specific. I have a 12 year old Thetford Aqua Flush V. The bowl seal closes with a flat blade running across bottom of rubber seal. The blade seal stopped holding water so I bought a new seal. Old seal was a bit rough on the bottom so I figured that was the problem as it takes a couple hours to empty. I tried Vaseline and silicone and that didn't help the seal. Kit comes with new bottom floor seal as well. Good idea as the old floorseal came off in pieces. Easy job to replace blade seal but now it leaks faster than the old one. I'm wondering if I could disassemble and stretch the spring, buy a new blade on eBay for $16 or just buy a new toilet for $100. Any experience with this model?
  • Try plumbers grease first. Then go with a new toilet. Porceline toilets are way nucer than the plastic ones.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
