rk911
Jul 15, 2019Explorer
Damdifino wrote:
So do you take the rubber seal off, or do you squeeze the wire between it and the flapper?
turn the water off and hold the flapper open with your foot. i left the gasket in place and *gently* run the edge if the coat hanger (anything like that will do...pipe cleaner, flat toothpick, etc) clean the crevice.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
