Red-Rover's avatar
Red-Rover
Toilet Flush
After flushing my Dometic toilet, I like to partially refill the bowl with water but to do so requires balancing on one leg while depressing the flush pedal only a small distance as I steady myself against a wall.
Has anyone developed a technique or modification that helps modulate the flush pedal?
  • I don't know how old you are (I'm only 66), but I stand on one foot and depress the pedal as needed. The shower door surround is right there on my right if I need to put a hand on that to balance - but rarely do.
    Rob
  • Use your hand to press the pedal to trigger the water. Gloves optional.
  • I fill my plastic water glass at the sink and just dump it in. Easy Peezie.
  • If you weren't so far away, I would offer to trade you for mine which has a hand operated lever. It does not suffer from THAT particular problem. ;-)
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
