JamesJudasPriest wrote:
JD and Beastlet wrote:
mobilefleet wrote:
step on the flush valve to open the bowl (or pull it back depending on which style you have) and take a toilet brush and clean real good behind and under the bowl seal, sometimes hard water deposits get in there and make the valve not quite seal all the way. Then take a qtip or popsicle stick and smear vaseline around the perimeter of the seal (with no water connected of course). It works
Being petroleum based, would Vaseline not attach the rubber seal?
x2 try silicon grease?
nope. Vaseline shouldn't be used on latex rubber. The seal isn't made of latex. 2 years no problems
