TUCQUALA
Apr 27, 2015Explorer
To The LeRoys:
I am using Torque Pro on a V10 Excursion, don't know which PID I am using, and can't find it on the app.
BUT, just make 2 new gauges, and use both PID's. I am pretty sure one will not show anything on the gauge, but if they both work, you can compare and keep the one you feel is accurate. FYI, my trans temps run 140-160 not towing, and usually will stay around 160-190 when towing and have hit 215 on long hills and 90 plus degrees temps.
Hope this helps.
Hope this helps.
