Boon Docker wrote:
...If the fridge is on a circuit all by itself, you could pull all the fuses except the fridge fuse then check current draw at the battery cable.
That's what I was planning to do - have everything "off" except fridge. I want to see if I can use the fridge while dry camping, or if I'm going to use the Yeti cooler that I, er, I mean Santa, gave me for Christmas. I FINALLY figured out how to disengage the Dometic heater...jeesh - was that a project.
Just bought a new AGM Group 31 battery (about the max weight my trailer tongue could take).
