dclark1946's avatar
dclark1946
Trailer brake wiring question( Mystery Now Solved)
Another question after crawling around under our new KZ Spree TT.
The wiring to the rear of the brake drums is only connected on the driver's side. The wires coming out of the back of the drums on the other side are taped off. Is the other side fed through the axle tube or what? The trailer brakes draw about 11A when supplied with 12V when using our electric trailer dolly.
I think I had measured brake current draw on each of the 4 wheels using a clamp on Ammeter on our 2007 Spree.
Mystery solved:
Thanks for your inputs. Based on those I was able to resolve this. My initial impression that the passenger side brake wires were not connected but just taped off was based on what I saw from the drivers side under the trailer where I could clearly see the wiring coming out from the plastic under belly liner and connecting to each of the brake drums. One of the wire pairs was laying across the top of the leaf spring which are mounted on top of the axle. I will need to reroute that pair. When I looked across to the other side to see how the wiring was routed I could see nothing but the wires coming out of the drums with tape on the ends.
This morning I decided to climb under the passenger side for a closer look. I did see a pair of black wires exiting the axle and connecting to the drum wires so what appeared to be taped off wires was really the connection to the wires coming out of the axle tube. Black wires, black brake drums and less then optimum lighting coupled with not knowing that manufacturers had started feeding the brake controller power down the axle tube led to my initial wrong conclusion. I am now a little wiser.
  • If you want to make sure those brakes are working. Jack a wheel slightly off the ground, pull the emergency break away plug or have someone step on the brake pedal or hit the manual brake switch, rotate the wheel to see if the brake locks up. Dont leave the break away plug out but long enough to check one brake at a time.
Having RV issues? Connect with others who have been in your shoes.24,200 PostsLatest Activity: Feb 18, 2025
