- philhExplorer IIIChristmas eve, went to Camping World, and walked out a hundred dollars poorer :)
Did get the curly cable for the trailer, and a bunch of other stuff.
And why was this moved to Tech? - BFL13Explorer II
dpgllg wrote:
Which cable length should be used for a 5th wheel? 4 feet or 6 feet?
Thanks!
Dave
It is sort of sad/funny when you see people hooking the breakaway line to the 5er's hitch head in the truck. Use one of the eye-pads in the truck bed.
The breakaway line should be the longest, last to go with a TT. First it will be off the ball and on the chains. Still have brakes with 7-pin. You don't want the breakaway to pull just yet. Only if the chains break loose. - Cummins12V98Explorer III
Thanks!
Dave
“Depends”
Get the 6’ and be done with it. - dpgllgExplorerWhich cable length should be used for a 5th wheel? 4 feet or 6 feet?
Thanks!
Dave - Cummins12V98Explorer III
ScottG wrote:
I have one of these that I really like. Never touches the ground.
Linky
I have the same one. Works great! - You could get a small electrical split bolt to shorten cable. Double cable back leaving appropriate slack. Secure loop with split bolt.
- philhExplorer IIII put one of those on my old trailer, great idea.
Need to fix this for the trip home. - wa8yxmExplorer IIICable is a common hardware store item. Ues. I'd go with thimbles (optional) and cable clamps... I would not SPLICE that cable I'd replace it with one cut the proper length.
Linky
Ditto. I have the 6 footer as well, on all my trailers.
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: May 15, 2020
