- Cummins12V98Explorer IIIContact GY tech. They will tell you when upping load range weigh your RV and add 5psi to what the weight/inflation chart for your specific tire says.
Better stopping traction, ride and tire wear. - sign_manExplorer
Cummins12V98 wrote:
May I ask the reason whysign man wrote:
When going from d rated to e rated Should the e rated tires always be inflated to the maximum pressure regardless of how much weight there is?
NO! - Cummins12V98Explorer III
NO! - Ralph_CramdenExplorer II.
- CALandLINExplorer
Anything above vehicle manufacturer recommended 65 PSI is optional. But, you waste your money for additional load capacity reserves if you don't use some of it.
Maximum inflation for Original Equipment trailer tires is a normal recommendation. It's not a requirement for higher load capacity replacements. - sign_manExplorerWhen going from d rated to e rated Should the e rated tires always be inflated to the maximum pressure regardless of how much weight there is?
- Ron3rdExplorer IIIThe Goodyear Endurance is a good tire as noted above, but the Carlisle Radial Trail is holding up very well too and getting good reviews and is a little cheaper.
Neither are the notorious "China Bomb" tires so you pay a bit more for them. I went with the Carlisle E rated tires, found the lowest online price at walmart.com, took that into my local America's Tire/Discount Tire store and the beat the price by a buck as they'll match any online price. - JIMNLINExplorer III
3 tons wrote:
From what I heard from a tire dealer there’s a reason why they are called ‘trailer tires’. When asked, he said that trailer tires have heavier sidewall construction to help deal with the scrubbing (e.g. twisting) that occurs on multi-axle configurations...Just saying, but I’m no expert.
ST tire manufacturers propaganda for several reasons. One biggie is...
FMVSS 571 tire testing
The testing for bead unseating resistance is identical for a ST and LT tire.
The testing for (1) bead unseating resistance and (2) strength were identical for tires representative of moderate to heavy 5th wheels and thus no advantage is given to either tire type.
Tire dealers that don't know this simply pass along any mis info as we know this to be. Size per size they both stand up to side stress issues however one has had in the past a terrible history of sidewall zippers and mostly tread delam issues. - 3_tonsExplorer IIIFrom what I heard from a tire dealer there’s a reason why they are called ‘trailer tires’. When asked, he said that trailer tires have heavier sidewall construction to help deal with the scrubbing (e.g. twisting) that occurs on multi-axle configurations...Just saying, but I’m no expert.
- MFLNomad II
Ralph Cramden wrote:
"trailer tires"
Nice pic Ralph! :C Everyone has an opinion about tires, some are even correct. You have to have some knowledge of tires, come on, let us know your thought???
Jerry
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
