lfr101's avatar
lfr101
Trailer wiring caused fire under dash
A friend of mine picked up a 18 ft House trailer to tow with his Ford Ranger.He knows it is small but is talking his wife into a bigger truck.
He towed the truck home with a GMC truck.
He took the truck to a major truck/trailer rental company that has a U in their name to have the 7 pin plug and brake controller installed.
When he got home he backed up to the trailer to try it out, once plugged he went to check out the light ,going back to the truck there was smoke coming from under the dash.Unplugging the truck saved it from burning up.
He went back to the installer and they question him saying that maybe the trailer was wired for a GMC not a Ford .I hooked the trailer to my Dodge and they all worked OK.
Now I was under the believe that all trailers are wired the same so they can be pulled by any type of truck.
The ford dealer said it would be $1300.00 to repair it.
It has been over 3 weeks and they (company U) are still jerking him around about paying for the damage.
My question is are are trailer wired the same ?
They want to send a insurance person to look at the trailer,
Thanks D
  • The #18 or #20 wiring in a lot of vehicles is really too small to handle the current used by the parking and tail lights ...
    When you add the clearance and tail lights on the trailer, it's a fire waiting to happen.
    Standard vehicle lighting: 4 X 36 Watt lamps = 12 Amps.
    Trailer lighting = ~8 to ~12 Amps.
    Total = ~20 to ~24 Amps.
  • What a crock. Trailer wiring is standard. IF, they ran the battery charge line from the TT to an incorrect wire the TT could have sent power through a wire not supposed to have 12 volts on it.
  • If the trailer is wired correctly they all should be the same.
    You can go to This Site and check the wiring on both the trailer and the truck for yourself
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Jan 02, 2026
