Chinolbz
Oct 29, 2019Explorer
Transfer Switch
I think my TS is dead. No 110v getting through. Any way to jump around it to keep me going while dry camping on a gen? Thanks
time2roll wrote:X2ADAD437 wrote:I thought standard TS was connected to the cord as default. If you start the generator there is often a 20 second delay to switch.
if transfer switch goes bad it should default to generator therefore you should have power when gen. is running. been there done that.
And when things fail they don't necessarily reset to some position. Could be a loose or burnt connection for all we know.
time2roll wrote:ADAD437 wrote:I thought standard TS was connected to the cord as default. If you start the generator there is often a 20 second delay to switch.
Chinolbz wrote:
No damage inside the TS. Panel breakers are good. Power to one side of the points. It won't engage the relay to move the arm to power up the AC side?
Chinolbz wrote:OK so just remove and connect the appropriate wires. Large wire nut or if there is room on the TS connectors for both wires use them.
