TenOC's avatar
TenOC
Nomad
Apr 25, 2021
TRC Surge Guard Model 34850 now TRASH ????
I have a TRC Surge Guard Model 34850 50 Amp Date Code 1616 (?). The Center female socket is showing major heat damage after camping for the week pugged into 50 amp service.
Cause ?
Is the surge guard Trash now?
Warranty ????
  • Are you saying the flat connctor which is the neutral vs the round ground is damaged?
    That pin like the 2 hots can carry up to 50A. Heat damage comes from poor connections or corrosion in either the male or female plugs or wires. What does your male plug look like? Time to replace?
    Do not use either plug until they are replaced as a open 50A neutral can cause significant damage to the rig due to very high voltage.
    I'd call and see if the unit can be repaired.
    Note: IF the pedestal hots are both connected to the same transformer hot then not only is the pedestal miswired but it's now possible for the neutral to carry up to 100A which is way over the rating. If there is 0V across the hots vs 240V then it's miswired and in violation of the electrical code.
  • Limited warranty against defects.......
    Warranty Policy
    Any questions regarding this warranty, please contact Southwire at
    1-800-780-4324, or by email at productinfo@southwire.com
    Sounds like bad/loose connection....not covered by warranty
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 19, 2026
