MakerMK's avatar
MakerMK
Trojan T-1275 Trouble
Newbie here.
I have a travel trailer that has a Trojan T-1275 battery that is around three years old. The camper spends most of it's time in a pole barn hooked up to a couple of 100 watt solar panels and a Schneider charge/load controller. I check the water level when I think about it (I know, it should be on a schedule) and the last time I checked it was about 1/8" below the top of the plates and the charge level was low. I topped the cells off with distilled water and gave it a couple of days to recharge.
Well, it didn't recharge. I initially thought I must have ruined the battery by letting it get low, but after checking the wiring of my solar system I discovered a bad connection. A much better problem to have than a dead battery! I moved the camper to a source of AC power and let the camper's system (not the Schneider) charge the battery. The next day I took hydrometer readings and they were still deep in the red/recharge zone. I let it charge for another day and there was no change.
I decided to take a voltage reading, so I disconnected the battery and let it sit overnight. When I checked it, it read 13.1 volts! I grabbed the hydrometer again and the readings were all still in the red/recharge zone. I suspected the hydrometer so I checked it with plain water and it read 1.0, or more precisely the water level was at the point where 1.0 would be if the scale went that far.
What the heck? I'm no battery guru, but this seems crazy! Do any of you folks have an explanation for this? I'm at a loss.
  • T1275s will be my next battery purchase. Nothing but good reports.
  • I had a pair of T-1275s in a past set-up. Great batteries for RVing!
    What you need is to charge the battery at 14.8v or so to get the SG up. I suspect the charger you had them on was only a 13.x voltage charger.
    Right now you have the acid at the bottom of the battery giving you that 13.1 volts, and the hydrometer is not getting at it. You need proper "gassing voltage" to get the electrolyte mixed from bottom to top.
    Make sure the solar controller's high set point is 14.8 volts too, or else it will happen again.
Having RV issues? Connect with others who have been in your shoes.24,203 PostsLatest Activity: Feb 22, 2025
