waynefi's avatar
waynefi
Truck power to trailer
One of the pins on the 7 pin connector is supposed to supply power to the trailer. Mine doesn’t seem to be working. If I measure the voltage at the battery, it does not go up at all when I connect the truck. If I disconnect the battery, with the truck connected and running, the trailer inside lights will not come on.
With the trailer disconnected, the voltage at the truck connector is 13.8.
What would stop the voltage from getting through? I don’t see any blown fuses.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 21, 2025
