time2roll
May 10, 2017Nomad
30 amp/hours is generally recoverable on an 8 hour drive. However you will not fully 100 percent charge the battery because the top charge is very slow. Much easier to to get more amps as you get down 50 percent discharged. So it may seem like you are sliding lower each day as you oscillate down to 50 percent and recharge to 70 or 80 percent. Assuming after a few days of this you will arrive and plug in all should be just fine.
Incandescent lights are a big draw so keep usage to a minimum or consider LED replacements.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
