rickst29
Jul 22, 2017Explorer
JCK wrote:
Do not know what size the gauge wire size is ..But my old truck 2004 Duramax there was a 40 amp fuse protecting the circuit . Don't think the factory would install a 40 amp fuse if the wiring could not handle it . Going on long trip this year would like to travel 2 days and third night campground to replenish water dump tanks . That should be enough to top of the batteries again if the truck is able to mostly keep up during the day.
The truck will "crank up the Alternator Output" when it see's it's own battery being discharged. But it doesn't actually see your Trailer battery very well through the long, skinny wire: You must either hook the Trailer up to your TV using a better, shorter cable, so that it sees the trailer batteries to be discharged; or you will probably need to do something like my scheme. If you use very little electricity between visits to "plug-in" campgrounds, then it won't matter - but if you do run the batteries down, then you'll need to do something different than simply plugging in the Bargeman and turning on the truck. If you do only that, then it will take many, many hours to recharge a pair of discharged trailer batteries. Are your traveling days > 6 hours long?
New Edit: Also, will you run a fridge on electric while towing? That would be a problem because a 12V fridge heater will discharge Trailer batteries to 65-75% before the Fridge begins to pull significant current from the TV. That leaves you only 15%-25% of total capacity available for actual use before needing to charge again. (I'm assuming "typical" SLA Trailer batteries, "typical" Tow Vehicle and Bargeman wiring, and a 120W 3-way fridge heater unit.)
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
