This afternoon I decided to do a quick bit of maintenance. Check the water heater anode rod and flush the tank. One thing lead to another. Why not sanitize the freshwater tank while I'm at it? To f...
I would suggest that the screw together tub drain is not wrench tightened, no need to, there's no pressure involved. If you can loosen the connection, see if you can possibly push the P trap connection upwards and then re tighten. Not a bad idea to stiffen up the bottom of the tub, I still have to do my floppy shower floor next spring.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
