MEXICOWANDERER's avatar
Jun 09, 2016
Turn Side Lights Capacitor Sizing Formula
I have to be careful because the following is a description of a proposed capacitor charging cycle timing circuit.
OBJECTIVE: Convert flashing turn signal to continuous signal for side illumination lighting.
DESCRIPTION: There will be one circuit for each side
SIGNAL: 12 volts. Duty cycle one second 50/50
LOAD 18 watt each side LED
Signal from turn signal switch will pass through a diode to prevent feedback. The pulse will charge an (?) rated electrolytic capacitor.
The capacitor charge will feed an 88 ohm coil Tyco battery fed relay, rendering a continuous signal as long as the signal pulse exits.
SENSITIVITY: I do not want an "overly" long time to elapse between initiation of trigger and lighting of load. Nor do I wish to have an excessively large capacitor capacity which will keep the side load lamp lit "too long" after the trigger pulse is removed.
Triggering pulse (for capacitor charging) can supply up to 10-amperes st one second intervals.
Remember the triggering pulse feeds the relay coil not the load.
I have today only to order the caps and intend to order 3 different uf just in case. I am going to choose 56 volt rated for longevity.
Too many years since college and sundial response internet has failed to download R/C and L/R/C charts.
Thanks
Having RV issues? Connect with others who have been in your shoes.24,353 PostsLatest Activity: Jan 23, 2026
