Gdetrailer
Nov 26, 2015Explorer III
gbopp wrote:Gdetrailer wrote:
AND less than stellar assembly line techs which most likely are not properly trained electricians to start with.
THIS, if for no other reason, is why we should check and tighten as needed.
Correct, however, even with copper wire there is a point of no returns if you OVER TIGHTEN the set screw.. Essentially flattening the wire and causing the wire to potentially work harden and get brittle to the point of breaking off due to vibration.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
