otrfun's avatar
otrfun
Explorer II
May 03, 2013
Using Clamp-On Multimeter to Check a/c Surge Current
I'm thinking about purchasing a Yamaha EF2400iSHC generator to power my 13,500 BTU a/c. I know the odds are in my favor that it will work, but ya never know.
Some of you have mentioned using clamp-on multimeters to check your a/c's surge current. Can any of you shed some light on which clamp-on multimeter you used and what your results were? Is anybody aware of a particular continuous or surge current reading that tends to exceed the capability of the EF2400iSHC? I know the EF2400iSHC is supposedly rated at 16.7 amps continuous and 20 amps surge. However, I've read here and there the EF2400iSHC can sustain a 30+ amp surge for 5 to 10 seconds.
I noticed Harbor Freight sells some cheap clamp-on multimeters with a "peak" function. Are these a complete waste of time and money? Or, should I invest in a more expensive unit that has the "inrush" capability? I'm thinking it might be worth the $100-$150 investment to increase my confidence the EF2400iSHC will work with my a/c unit.
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
