wa8yxm
Sep 08, 2019Explorer III
My Concerns have to do with wire size. Is the NEUTRAL the same size as the two HOT leads (IE. #6) and is the ground heavy enough (likely yes)
IF so you have two options.
one a pigtail adapter all 4 wires Dryer plug and RV-50 amp outlet or
install the RV-50 amp outlet next to the dryer outlet
But only if the Neutral is the same gauge as the hots for if you plut in a 30 amp rig the neutral carries all 30 amps.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
