NEOK's avatar
NEOK
Using shore power with bad batteries
I have two batteries that only show 11v on my multimeter. I have tried to charge them up but can't get them to read above 11 volts. Is it safe to use the RV occasionally plugged into AC power until I can replace the batteries in a couple of months?
  • As said above, maybe only one battery is bad. Just remove the bad one.
  • Yes, just disconnect the batts (wires off neg post, not by using disconnect switch)and the converter will do all the "12v" work.
    By leaving the positive post wires on, the slides , jacks etc that are battery direct will still have a path for the converter to run them. If you remove the batts entirely, you can clamp those pos wire terminals together (eg vice grip pliers) and get the path, but be careful not to let the clamp touch the frame (big sparks!)
    If you leave soon to be dead batts on the converter, the converter might get overworked trying to charge them (not too sure about that, but why take a chance?)
  • Are they both 12v batteries? You can always charge them separately and then only use the battery that reaches full voltage until you can replace them. :C
  • Depends why they are low. If a cell is bad or shorted, it is possible to catch fire.
    But even if it is safe, it could be a strain on your converter/charger.
    I would rather have a battery that charges up to full voltage and dies quickly than have one that won't reach full charge.
    That's my opinion ;)
    • OK if you connect to them and it does not cause the converter to work hard
    • The batteries must not bubble -- check all 12 cells after 24 hours
    • The house voltage must not go weird -- it has to stay where good batteries would have it.
