Patrick45's avatar
Patrick45
vented box for Honda 2200 generator
My brother in law wants to place his Honda 2200 generator on a cargo platform in the heavy duty receiver at the back of his travel trailer. He would like a vented ready made metal box that he can secure there.
He won't be running the generator with the box over it but is concerned about not ventilating the gas in the machine and a gas can there.
Thank you for suggestions, experiences and pictures.
  • valhalla360 wrote:
    when was the last time you saw a car randomly blow up from gas fumes collecting below the car?
    You are correct, I have never seen a car blow up from gasoline fumes.
    However, I have seen gasoline fumes travel across the ground about 20' and ignite from a fire. I think it's called a flashover? I don't know.
    I do know it was scary.
  • gbopp wrote:
    valhalla360 wrote:
    Gasoline vapors are heavier than air so they drop down naturally and then blow away.
    Occasionally they blow up. ;)
    Other than in movies where the rules of physics don't apply...
    There is a reason gas boats have bilge fans that you run before starting the engine and cars don't.
  • jjrbus wrote:
    The Honda cap itself will stop fumes for the generator.
    x2
  • As long as there are some open drain holes at the bottom or even just a poorly fit seal at the bottom, it's fine.
  • Wish it not such a pain to post pictures here. The Honda cap itself will stop fumes for the generator. Gas fumes are heavier than air so a simple vent in the bottom of the box will keep fumes to a minimum.
    I am in the process of building a new box for my Honda and will be running the gen in the box. I will have a vent line running from the extended run tank to outside the box, gas tank and gen are in same box.
Having RV issues? Connect with others who have been in your shoes.24,234 PostsLatest Activity: Apr 14, 2025
