jrnymn7
Oct 30, 2014Explorer
Mex said;
"Well an IR thermocouple could not define one-tenth of one degree difference between ambient temperature and both copper battery posts, so I'm not going to worry myself sick over the issue. This isn't like dealing with nitroglycerine where one small boo-boo makes for a spectacular result.
The accumulator is constructed of pure lead plates, right? The mats have 1.300 specific gravity electrolyte soaked into them, right? The construction and chemistry is the same as any other AGM, do you disagree? If the plates were alloyed with something weird like palladium or bismuth, I would be very cautious about deviating from OEM specifications. But they aren't. It waddles, quacks and has feathers, so it is indeed an AGM battery and it can well tolerate 13.75 volts float up to around 30-32C. These critters live day in and day out in RV's and emergency vehicles, where charging system voltage ranges from 13.8 - 14.4 "
Pnichols said;
"But didn't you say you were floating them (assuming day after day?) at 13.75V? If that kind of float voltage ruins wet cell batteries over time (as all in the forums say, due to their converter experiences), why wouldn't it ruin an AGM battery where the manufacturer specifically states to use 13.2V for float? It makes me think that Lifeline has something unbeknown to us in their AGM construction or chemistry that is different enough for them to recommend a float voltage lower than what most other AGM manufacturers specify.
That's what concerns me about what you are doing.
By the way, I think those temperatures in the temperature versus float voltage charts refer to the most logical thing - ambient air temperatures that the battery is sitting in."
...And there it is! It's all about temperature. Not outside ambient temperature necessarily, but cell temperature. If for example, it is a nice sunny 85*F day, but the battery compartment is say 110*F, then the batteries can only be brought up say another 5*F before they will start to gas. How much voltage does one think it would take to raise the battery's internal temperature by a measly 5 degrees F ??? And left unattended to for extended periods of time, how long does one think it would take for that battery to lose enough water to expose the plates?
Moreover, during normal daily cycling, higher temperatures greatly reduce battery longevity. For example, daily cycling a battery stored in a 110*F cabinet could very well doom that battery to a 2-3 year lifespan.
Now for some real world, logical analysis, as opposed to an emotional frenzied reaction; usually symptomatic of ignorance:
I was experiencing very excessive gassing with my 4 gc-2 batteries. So I thought it was from the higher voltages (14.8-15.2v) I was using. And, in a way, it was. But I now know it was a result of lack of ventilation and temperature compensation. You see, I have been charging at the same voltages for weeks now, but at lower ambient temperatures, and with the batteries completely open to lots of fresh air. The result? My batteries are no longer gassing excessively. In fact, after doing several 15.2 volt top charges, and a 16v EQ'ing, there was very little, if any water loss.
Now imagine if I was long-term floating those batteries under the same conditions, i.e; with insufficient ventilation and/or temperature compensation. Do you think maybe, just maybe, the lack of ventilation and higher resulting temperatures could eventually cause my batteries to lose water? After all, it does not require voltages in excess of 14v to cause gassing, necessarily. It is the resulting cell temperatures, at or above their inherent gassing temperatures, that causes water loss.
I leave this with you for your sound consideration.
Pnichols said;
