GordonThree
Jul 30, 2018Explorer
CA Traveler wrote:
Measuring the shunt voltage is a good check but requires a voltmeter to measure very low voltages. A 500A 50mV shunt would measure 0.01V at 100A for example.
That's a good point. A 4 digit meter in the 2v range should see something. A 5 digit or analog meter would be ideal. A 3 digit likely won't register.
Another test would be a clamp ammeter on the cable feeding the shunt. It will at least confirm if current is flowing through or bypassing it some how.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
